Thrust Angle experts - I need Advice
Old Apr 21, 2004 | 07:18 PM
Scotts 02 SS's Avatar
Question Thrust Angle experts - I need Advice
Had new tires installed today and a alignment. Technician said the rear thrust angle was off a little. The printout says the thrust angle is 0.16. He said there is no way for him to adjust it. Is 0.16 off very bad or is it OK? If it is needing adjustment, will adj. lower control arms correct the thrust angle? Do you have to loosen the axle to adjust the LCA's? Thanks for any help.
