Question on Relocation brackets
Old Apr 21, 2004 | 11:01 PM
02CamaroZ28's Avatar
Default Question on Relocation brackets
Right now I have the sportlines and looking to gain a little more traction. All I have is a APHR. Im going to be getting LCA and SFC this week and want to know what you think about relocation brackets.
I might be changing out springs to a more drag friendly setup in the future....so if i go with weld in now with sportlines, would they still be usable with a different ride height. Or is it once theyre welding in, im stuck.....
Any info appreciated
Mark
Old Apr 21, 2004 | 11:03 PM
Cal's Avatar
Cal
Many of them have two sets of holes you can use. You can also still use the original mounting location without removing the brackets.
Old Apr 21, 2004 | 11:26 PM
steelsnow's Avatar
it helped me, but i did springs shocks and relos at the same time.
Old Apr 22, 2004 | 12:46 AM
Turo's Avatar
you should be fine, the reloc brackets will help straight line traction nomatter what springs you have, the key is to put the lca in the right hole. with the sportlines, you probably want to go to the lowest setting for best results
Old Apr 22, 2004 | 03:18 AM
DARK AGE 53's Avatar
Just get the BMR bolt-on relocation brackets and you'll be fine.
Al
