Bilstein and coil-overs
Old Apr 19, 2013 | 09:46 PM
bent1's Avatar
Default Bilstein and coil-overs
Can you install coil-over front springs on these shocks? 93-02 Fbody Bilstein Heavy Duty Shock (Front) Part #BE52406M2
Old Apr 20, 2013 | 05:44 PM
JD_AMG's Avatar
Maybe its just wrong wording you, but what other type of spring would you install???
Old Apr 20, 2013 | 08:00 PM
LS1121's Avatar
You will need to re-use the spring perch from your old shock, from looking at pictures of this shock I do not see the perch.
Old Apr 20, 2013 | 11:23 PM
bent1's Avatar
Right now I have Eibach coil over springs on a factory shock (front). I want to replace just the shock
