Koni Install Questions.
1) The large flat washer: Where does this go? On the front shocks right? Do I need it being that the original shocks didn't have this?
2)How do I assemble these bushing for the rears? Is it Shock>Washer (Cupped toward bushing)>bushing>Car>Bushing>Washer (cupped toward bushing again)>nut? I'm very confused.
These directions suck.
Finally, how do I know when I'm at full soft/full stiff for the settings. Will the adjustment rod/**** stop turning at a certain point? Can I adjust these before I install them or they have to be under load?
2. Post your photo and we can confirm you have it right-- much easier that way.
3. Did you search?
https://ls1tech.com/forums/showpost....4&postcount=11
Adjust them either before or after -- it matters not. They stop where it gets hard to go any further -- try it...
