handling question
Old Apr 27, 2004 | 12:50 AM
z2898ls1's Avatar
Default handling question
Has anybody ever had a prob with there rears locking up on you. like ill be coming up to a corner and if i brake hard alot of time my rear will lock up on me. anyway to stop this
Old Apr 27, 2004 | 02:26 PM
4mula1's Avatar
Do you have ABS or not?
Old Apr 27, 2004 | 11:32 PM
z2898ls1's Avatar
yes i have abs
Old Apr 30, 2004 | 11:15 AM
A BAD T/A's Avatar
With abs, it should not happen at all! Could be a sensor wire off or broken, a bad sensor, etc. Have you had any work done on the front or rear where something could have disconnected/broken a wire or sensor?
Old Apr 30, 2004 | 02:46 PM
som_ss_01's Avatar
also might be a bad proportioning valve. These are sapossed to control fluid pressure and not let as much pressure go to the rears so they dont lock up under hard braking. They keep more line pressure to the fronts so that rear do not lock, causing loss of control under hard braking.
-Brian
Old Apr 30, 2004 | 04:35 PM
VIP1's Avatar
Copy & Paste Moderator
I think 98 and later got an electronic proportioning valve.
Either way, its possible that its malfunctioning (but less likely).
Most likely its an issue with the sensors, like "A BAD T/A" said.
Unplug, inspect, and replug the ABS sensor at each wheel to
see if there are any issues there.
--VIP1
