coilovers
Old Jun 22, 2013 | 11:59 PM
  #41
JakeFusion's Avatar
Super Hulk Smash
Yeah, you can still order those online. They come with better mounts and aren't adjustable. Getting them set like you want with the springs and shocks engineered to work together probably provides a better overall ride and takes the element and error of trying to make multiple adjustments...
http://www.lgmotorsports.com/product...oducts_id=1558
Old Jun 23, 2013 | 01:38 AM
  #42
fasteddy's Avatar
If its the same shock as the vette G2.....the valving was perfect....it was worth every penny. I consistently shaved 2 seconds off a 1.31 time at WS in CA. And the car felt more sure footed and controlled. And the drive to/from the track was fine....little firmer than stock but very comfortable. They know their stuff over there at LG....they even set the ride hieght to my specs before shipping....and it was spot on...no adjustment needed.
Thanks for the heads up....I'll check em out.
I was going to do another suspension option.....but if these are available I'm all over it.
Old Jun 24, 2013 | 01:47 PM
  #43
Sam Strano's Avatar
LS1TECH Sponsor
I wish you would have called because I'm mandated to advertise them for a certain price, but there are specials. And because I know how to set them up, but I can't be giving away all my secrets.
__________________
Old Jun 24, 2013 | 08:57 PM
  #44
scj's Avatar
scj
I called and spoke to a woman in your office I suppose. Was quoted the online price and asked if you priced matched with the answer being no, I just moved on.
Old Jun 25, 2013 | 12:53 PM
  #45
Sam Strano's Avatar
LS1TECH Sponsor
Just ping me in a situation like that. Again, it's a tough situation because KW has a MAP policy, and they can be strange about who they hold to it. Lots of games get played with "in the cart discounts" and crap like that. Having said that, when it comes to spring rates, and playing with damping for particular needs I'm way, way better at that than anyone else you are going to find.
Sadly, nobody gave me any parts to figure this all out, I have to buy them too and that costs money. And it takes time to learn (which costs a lot of money).
__________________
Old Jun 25, 2013 | 04:22 PM
  #46
JakeFusion's Avatar
Super Hulk Smash
Sam, then I might go that route. The KW Coilovers, Hyperco springs, and the 35/22 adj swaybar combo from you.
Old Jun 25, 2013 | 04:24 PM
  #47
Blackbird-WS6's Avatar
im looking into Viking coilovers all around or GC kit right now. not sure which way ill go. getting all the info i can first.
i do need to get a front sway bar from Sam tho.
Old Jun 25, 2013 | 04:32 PM
  #48
scj's Avatar
scj
No doubt Sam. If I get to the point where I'd like to mess with the spring rates as well as get the watts link and sways I'll give you a call.
Old Jun 29, 2013 | 08:48 PM
  #49
scj's Avatar
scj
Problem solved.
Old Jun 29, 2013 | 09:19 PM
  #50
Can water get in there and rust over that adjuster??
Old Jun 29, 2013 | 09:31 PM
  #51
Guitar's Avatar
That would be easily fixed with either a bolt or a grommet of sorts.
Old Jun 29, 2013 | 11:20 PM
  #52
scj's Avatar
scj
This car will never see rain, and the only water it will see will be the water from washing it. I will have this plugged with a rubber grommet once the engine bay is all finished up though.
