My Brakes Suck, Help!
Old Jul 10, 2013 | 05:07 PM
nomasterase's Avatar
Originally Posted by Neenjah
Thanks for replying man.
Pedal is rock solid with the car off. Start it up and it can do either, step on the pedal fast? Rock Solid. Gently apply pressure... it goes down in stages: a few inches.. then a few more until youre at the floor.
What you just posted is textbook description of an internally bypassing master cylinder. Id start by replacing it
Old Jul 10, 2013 | 06:20 PM
SparkyJJO's Avatar
Yeah when I apply the brake pedal i hear a slighy hisd/squeak
A little bit of that when you hit it is normal (every car I've had makes a slight initial hiss if I hit it) but it shouldn't be constant.
Old Jul 14, 2013 | 05:07 PM
Neenjah's Avatar
its just when i initially press on it.
Old Jul 15, 2013 | 11:39 AM
imma_stocker's Avatar
After putting my car back together a connection at the ABS block was leaking just enough to make a hissing sound when I pressed and released the brake pedal. Locked them all down and no more hissing sound or squishy pedal.
Might want to triple check those connections. Free and only takes a few minutes with the right wrenches.
Old Jul 21, 2013 | 07:41 PM
fastsspr's Avatar
I think it point to a problem with the master cylinder probably it need to be replaced.
Old Jul 21, 2013 | 10:53 PM
1981TA's Avatar
Sounds like you got a bad master, especially with it slowly sinking to the floor under consistent pressure.
Old Jul 25, 2013 | 09:29 PM
Jurgen's Avatar
How many miles on the car ? Sounds like a master to me .
