need brake help
Old May 4, 2004 | 10:48 AM
wickdws6bird's Avatar
Default need brake help
i have done everything that i can think of to fix my squeaky brakes but buy a whole new baer kit......new rotors, pads, even the stuff on the backs of the pads
im lookin for any ideas anyone may have on how to fix this problem
thanks
Old May 4, 2004 | 02:56 PM
ttt.....
Old May 4, 2004 | 08:43 PM
Wildman's Avatar
Well, it might be the pads you are using. Some high performance pads squeek. I have heard Hawk pads are good. I like my Durastop pads except IMO they leave too much dust.
That backing material is real important though. If you see any metal to metal contact where the brake pistons meet the pads, that can create a squeek.
Old May 5, 2004 | 12:23 PM
4mula1's Avatar
As you replaced parts, has the sound (pitch, duration) of the squeak changed any?
Old May 5, 2004 | 04:43 PM
VIP1's Avatar
Copy & Paste Moderator
They are supposed to be in contact.
An anti-squeel shim is usually attached to the back of pads to help with the noise. If its not there, then you can try that. Anti-squeel greese usually comes with pads too (you apply it to the back of the pad). If your pads didnt come with any, or you didnt apply it, then that could contribute to the noise.
--VIP1
Old May 5, 2004 | 04:46 PM
Wildman's Avatar
--VIP1
Maybe I should have clarified, I agree with VIP1. If you do not have the shim, and there is metal to metal contact, you will squeel.
Old May 5, 2004 | 04:52 PM
TTopJohn's Avatar
My recipe for quiet brakes: LOTS of anti squeal goop on the backs of the pads + Stock GM replacement pads OR Raybestos Quiet Stop pads.
