LCA Question
Old May 8, 2004 | 11:01 AM
Zero_FactiX's Avatar
Default LCA Question
Are the bearings in LCA's supposed to move? and if they're not could this be the culpret of my massive wheelhop?
Old May 8, 2004 | 02:58 PM
John95Z28's Avatar
Do you mean bearing as in a spherical type (heim) bearing, or bushing as in rubber or polyurethane?
Old May 8, 2004 | 04:18 PM
Both, when i got them one set was siezed up and the other set was not put together yet.
Old May 8, 2004 | 05:43 PM
2w0s060's Avatar
What brand are these??
Old May 8, 2004 | 06:30 PM
Pro fab racing but can anyone answer my question?
Old May 8, 2004 | 07:52 PM
2w0s060's Avatar
Ok, so are saying these control arms have both a heim end and a poly end. If so which end is moving? Give us some more detail and I will glad to try to help
Old May 9, 2004 | 11:53 AM
Both ends have a plastic bushing with a metal tube that slides in it which the bolt slides through. the plastic piece and the metal tube can both move freely and will fall out. Hope this helps describe what you need to know to help me.
