which control arm reloc. bracket setting.
Old Dec 28, 2013 | 11:20 PM
johnLs1camaro's Avatar
Default which control arm reloc. bracket setting.
I am installing my 9" and I was curious what setup everyone usually goes with on their lower control arm relocation brackets.. I currently have my rear control arm in the very bottom hole, didn't know if that would be too aggressive for my car. I understand Ill probably have to make some changes at the track but didn't know if I should start on the bottom hole and move up.. its a 600hp car with a 4k stall and a 3.89 gear if that matters.
Old Dec 29, 2013 | 01:54 AM
Burken01's Avatar
The lowest hole will hit the tires the hardest when launching..
Everyone recommends the lowest setting
