Shock Mount Isolator
Old Dec 29, 2013 | 04:46 PM
TA_Freak's Avatar
Default Shock Mount Isolator
Today I decided to tear everything out and try to find out why my steering and suspension feels so sloppy. I was shocked (no pun intended) to pull out a shock assembly to find that there was NO spring pressure and the hole from the shock mount was totally reamed out. Part of me feels like a dumb *** ... and the other part is just glad that I found the issue.
* I'm not sure that "isolator" is the right part description. It's the very top piece that sits in the top of the shock mount.
Old Dec 30, 2013 | 12:29 AM
99Bluz28's Avatar
Yes, that's the correct name. Look for either Moog #K6573 or Monroe#903933
Old Dec 30, 2013 | 04:35 PM
TA_Freak's Avatar
Thanks ... I used the stockers. That's how I knew that I left those pieces out... not to mention how squirrelly the steering and suspension has felt. I saw them sitting on the shelf next to the stock shock mounts. If I hadn't had lowering springs, I probably would have had to compress the springs prior to removing the assembly. Things would have been violent with the taller stock spring.
