Suspension question EIBACH lowering kit
I have Bilstein shocks in the car that came with the Eibach kit. I will replace the shocks, my question is the coil springs. If they are not broke i assume they should not need replacing? Also if i were to go with say Koni shocks instead of the bilsteins i have now any special model shock i need to look at to match the springs. Any advice appreciated.
Some of the eibachs do sag in the rear, but if yours aren't I would not replace them for no reason. If you wanted to try a different rate spring since you're going with new shocks, now would be a good time.
But the real question for the OP is, which Eibachs, are they the Pro-kit, Sportline or the factory SLP optioned (I ask due to them being on bilstein shocks that long ago), if there the factory SLP Eibachs I'd probably keep them, if there a pro kit then I would go with something known to ride better?
