Front drag setup
Old Jan 26, 2014 | 02:42 PM
021le's Avatar
Default Front drag setup
Here are the current mods.
2002 1le a4 Navy Blue Metallic 25k and counting
Yank 4000 RPM stall converter
233/236 custom cam
upgraded springs/retainers/pushrods
upgrade oil pump
custom tune
Hooker long tube headers
Underdrive crank pulley
MSD wires
egr/air delete
Optima red top battery
Intake lid with K&N air filter
Lanes true dual 3in exhaust with twister mufflers dumped
Dr. Gas X pipe
Auburn locking rear end with 4:10 Richmond gears, T/A cover
Eibach 2 in. lowering springs
bmr panard bar
QA1 rear shocks
Drag bags in rear springs
subframe connectors
Baer Eradispeed rotors
ngk afx wide band
aeroforce gauge
be-cool radiator
trans cooler
front sway bare removed
on weld rt-s 15/10 with 275/50-15 mt drag radials@20psi, 17x4.5" rts up front with M&h radials
1.53 60ft
7.24 1/8th
93.79 mph
11.37 1/4
117.55 mph
3600# with driver, only rear seat/spare removed.
will only hook launching from idle, Every time I would try and stall it up is would only cut a 1.9 or worse 60ft.
front suspension is stock except the Eibach 2 in. lowering springs.
I have bad motor mounts, want to go turbo way down the road.
Was looking at replacing the k-member and mounts.
and getting a front shock/coil-over kit.
I want to get the 60 ft's in the 1.45-50 range.
Goal is to get into the 10's.
any suggestions on brands etc..?
Old Jan 26, 2014 | 02:46 PM
jsteele90's Avatar
i would do QA1 or Strange coil overs in the front. Remove the front sway bar. Replacing your motor mounts should definitely be a priority also. The tubular k member is a great mod as it drops weight and makes the car much easier to work on from underneath. for the rear i would ditch the lowering springs and install stock springs.
Old Jan 26, 2014 | 06:45 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
233/236 custom cam
upgrade oil pump
custom tune
MSD wires
egr/air delete
Dr. Gas X pipe
QA1 rear shocks
subframe connectors
ngk afx wide band
aeroforce gauge
be-cool radiator
trans cooler
1.53 60ft
7.24 1/8th
93.79 mph
11.37 1/4
117.55 mph
Which QA1 rear shocks do you have? Any other suspension parts on the car other than what is listed?
I have a proven working combo that will help you get the 60s as good as possible. We manufacture the highest quality suspension parts and have the best prices you will find, plus the install and tuning experience to get your goals achieved. Give us a call and we would be glad to help you out.
Old Jan 26, 2014 | 07:02 PM
021le's Avatar
the single adjustable ones.
Have a bmr panard bar on there 2, that is everything that I can think of.
Old Jan 26, 2014 | 09:03 PM
GTO1_OHIO's Avatar
Drop to 16-17lbs and go to Hoosier DRs
Old Jan 28, 2014 | 09:29 AM
ssvert99's Avatar
There is a few more parts that will benefit you for sure, such as a set of front shocks from Afco, Strange, or Viking. Then you will most likely benefit from a set of LCAs and relocators, and a short version torque arm will help hit the radials a bit harder at the launch. A k-member isn't a bad idea by any means, but other than weight loss and and ease of accessibility to the exhaust and other engine parts there won't be much of a loss in et's.
I will strongly suggest to lose the lowering springs right now... When you get a good set of front shocks(coil-overs) they will be ride height adjustable. Replace your rear springs with a good ol' set of stock springs with the hose mod done on top.
Your 60s are not too bad right now, but with the right parts on the car we can get your goals achieved and enable you to go much father in the future.
Give us a call... We can get you set up with the right combo of parts for you and we have the guaranteed lowest prices and highest quality on the market.
