ride height issue
Old Mar 25, 2014 | 12:49 PM
bgrill20's Avatar
Default ride height issue
I have a 1967 Camaro ls1,4l60e swap. we are using the stock control arms with 2'' drop spindles and a 2'' drop coil spring and im still high riding. any info would be great.
thanks.
Bill Grill
#drive fast we need cars!!!
Old Mar 26, 2014 | 12:34 AM
1967camaro78's Avatar
I am actually having the other issue I have 67 camaro 6.0/4l60e with 2 inch drop spindles tubular control arms and qa1 coil overs. I had to crank coil overs up almost all the way and still tucking tires. I need to find some different spindles stock height I think then I can adjust coil overs. Now my issue is finding stock height spindles that are a cast piece with bracket and steering built in. If I wanted drop spindles I can find them all day long. Maybe you can try different control arm and coil overs??
Old Mar 26, 2014 | 02:40 PM
leadfoot4's Avatar
thanks.
Bill Grill
What are you using for front springs? I would think that any spring designed for an older, IRON engine, would be too stiff and/or too tall for a car with an LS engine....
In your case, you may just need a taller front spring....
Old Mar 27, 2014 | 11:53 PM
I see that they make a coil spacer 1 inch and 2 inch would this work. Sorry no trying to steal you thread.
Old Mar 28, 2014 | 06:55 AM
leadfoot4's Avatar
I would think that would solve your problem....
