Adjustable phb question
Old Mar 26, 2014 | 09:56 AM
Tolley's94z28's Avatar
Default Adjustable phb question
When I jack it up to adjust it, should I jack the car up by the axle so it essentially sits at ride height while I adjust? Or do I even need to jack it up at all?
Old Mar 26, 2014 | 10:08 AM
TA_Freak's Avatar
Yes.... I loaded my axle by jacking under the rear end. Obviously have jack stands under it too - just not supporting the axle. I measured exactly how much I needed to shift the axle before I started the work and adjusted that much. Then drive it - even do a few circle 8s and measure again. At least that's how I did it.
Old Mar 26, 2014 | 12:32 PM
Daniel Richards's Avatar
IT MUST HAVE THE SUSPENSION LOADED, for me I just backed the car up on a set of ramps, but depending which PHB you have, which direction you installed it and how low you are you could conceivable adjust it while it sits flat on the ground.
