Relocation bracket
Old May 3, 2014 | 09:20 PM
jag42420's Avatar
Default Relocation bracket
I ordered a 4L60E tranny. It does not have the tail shaft torque arm bracket, so I need to order a torque arm relocation bracket. I also have Bassani duals, so I need to clear those. Recommendations?
Old May 3, 2014 | 10:54 PM
jag42420's Avatar
The relocation arm needs to work with the stock torque arm for now.
Old May 4, 2014 | 02:10 AM
99Bluz28's Avatar
I like the UMI's the best, but the BMRs are also a good option.
http://umiperformance.com/catalog/in...roducts_id=203
http://www.bmrsuspension.com/?page=p...&productid=329
You'll also need to buy a Energy Suspension front TA bushing #3-1111G to use with your stock gm torque arm.
http://www.summitracing.com/parts/ens-3-1111g/overview/
Old May 5, 2014 | 04:58 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Give us a call here at the shop and we can definitely get you set up with parts that will work for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
Old May 7, 2014 | 05:48 PM
guppymech's Avatar
Do yourself a favor and measure from some point of reference on your trans yoke to the tunnel so you can set your new trans at the same height to avoid driveline vibrations. I bought a UMI relocation crossmember for my '94 and found the new xmbr set the trans .375 lower than stock. I shimmed up the trans mount to correct this. I don't understand how they can build them this far off, it's not rocket science.
Old May 8, 2014 | 09:58 AM
BMR Sales2's Avatar
A lot of the driveline vibrations that come from installing a torque arm relocation crossmember also come from a change in pinion angle due to mounting the front of the torque arm in a location that is different from the factory. I really like to team up our torque arm relocation crossmembers with our adjustable torque arms so you can use the instant center adjustments on the crossmember. To use those adjustments you have to be able to adjust the pinion angle which requires an adjustable torque arm.
__________________
Glenn ***
Sales Tech
813.986.9302
Old May 8, 2014 | 10:19 AM
guppymech's Avatar
^^^Your adjustable torque arm it on my 'to buy' list. I like the fact that you elongate the lower bolt hole on the torque arm bracket to account for the distance change between the torque arm rod ends when changing pinion angle. It's a fine point most of the other manufacturers seemed to miss.
Old May 8, 2014 | 10:22 AM
BMR Sales2's Avatar
We definitely appreciate the good words and when you are ready to buy one let us know and we will make sure you get taken care of.
__________________
Glenn ***
Sales Tech
813.986.9302
Old May 9, 2014 | 09:50 PM
jag42420's Avatar
Got a BMR TCC-007 on the way. Thanks for the feedback all. It should be here Monday or Tuesday. I will definitely take some pre-measurements on positioning.
Old May 9, 2014 | 10:51 PM
JakeFusion's Avatar
Super Hulk Smash
I have the BMR 4L60E crossmember and BMR Adjustable full-length TA. Seems to clear the Kooks TDs without much issue.
