Help with Spohn solid motor mounts
Old May 4, 2014 | 02:44 PM
CMURDAx's Avatar
Default Help with Spohn solid motor mounts
As the title states, Im installing a set of Spohn solid motor mounts into my 2000 Z. They are marked L and R so I went ahead and put the R on the passenger side of the car. No problems there. Fits great and went in like butter after raising the motor a bit. My driver side on the other hand is not going so smoothly. The L mount is taller than the R by about a 1/2". Ive got the mount shoved in right now with my motor lifted as far as it will go up due to the other mount. I feel like it shouldnt tweak my motor up as much as it is. Anyone else have this problem or did I make the noob mistake and put the wrong one on the passenger side. Any help will be great.
Old May 8, 2014 | 09:50 AM
deerslayinrednek's Avatar
It'll fit but it is a bit of a pain
Old May 8, 2014 | 11:51 AM
MTN_Z's Avatar
Yeah, just keep one side loose and keep working at it. I had to mess with mine for quite a while to get them lined up.
