Welding Subframe Connectors Question?
Old May 17, 2004 | 10:42 PM
HOTROD98Z's Avatar
Default Welding Subframe Connectors Question?
Hey guys i am going to be welding in my connectors here within the next week or so and was just wondering if anyone has welded them in without pulling up the carpet and if they had any problems doing this.
Old May 17, 2004 | 11:25 PM
1320_PERFORMANCE's Avatar
I welded my bmr boxed sfc's w/ my carpet on no problems, just keep your eye on the carpet though.
Mark
Old May 18, 2004 | 02:15 AM
Jeffs99SS's Avatar
Agreed, just make sure it's not getting too hot inside the car. I welded my boxed BMR's with no issues.
Jeff
Old May 18, 2004 | 06:55 AM
mitchntx's Avatar
Stitch weld them in. Shouldn't be a problem
Old May 18, 2004 | 04:45 PM
Viper's Avatar
SLP's here, no carpet problems, stich welded as mitchntx said.
Old May 18, 2004 | 10:21 PM
Cheatin' Chad's Avatar
You really shouldn't be welding a continuious bead long enough to start the carpet/padding on fire anyway.You're dealing with relatively thing sheetmetal. Extreme heat will warp and/or permanently weaken the metal.
If welded as Mitch originally suggested there should be no problem.
1.5 to 2 inches at a time move from one area to another to limit hot spotting.
Old May 20, 2004 | 12:58 PM
NOZR1's Avatar
Should you disconnect the battery?
Old May 20, 2004 | 01:58 PM
Yes, to prevent damage to the pcm and other modules.
Old May 20, 2004 | 04:07 PM
I always disconnect the battery when I am working on the car. It's good practice.ESPECIALLY when you are doing something like welding.
Old May 24, 2004 | 12:39 AM
Cal's Avatar
Cal
The places that you weld SFC's to on an Fbody don't have carpet on the other side. This is more of a problem on Mustangs.
