Rack leak question and recommendation
Any chance that that could be causing the leak? I'm going to tighten it to the right specs tomorrow and see.
If it doesn't stop the leak, what is a good recommendation for a rack on a `99 TA?
http://www.superchevy.com/how-to/cha...k-steer-clear/
& here for a rebuild:
http://shop.rackdoctor.net
On a related note, what PS cooler are you using? If the OEM unit, replace it and go with an aftermarket one for starters, there is a huge thread about them failing resulting in coolant in PS fluid and PS fluid in coolant. What a mess. GM originally added the coolers to deal with failures.
https://ls1tech.com/forums/generatio...oler-pics.html
https://ls1tech.com/forums/general-m...g-success.html
Actually I just replaced the pressure hose a month ago. It was leaking at the passenger side boot. It seems to have stopped since I adjusted the pre-load properly.
