Ground Clearance suggestions?
Old Sep 15, 2014 | 08:04 PM
ls1charged's Avatar
Default Ground Clearance suggestions?
Any suggestions on how to gain a little ground clearance? I know it probably sounds crazy lol but Can i do anything to the suspension that will help get the car to sit even an inch higher will help??? Im looking into getting different rims and tires as well to see if that helps enough! Running 275/40/17's all the way around right now! thanks
Old Sep 15, 2014 | 11:26 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
front ? rear ? overall ?
Old Sep 16, 2014 | 07:17 AM
ls1charged's Avatar
Front is main concern
Old Sep 16, 2014 | 08:23 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
Best option for you is to get into an adjustable set of coil-overs. You will benefit from adjustable shock valving and adjustable ride height. Best bang for the buck is the Viking brand shocks, we sell a ton of these and have had no issues at all. They come with 19 position external valving and a great 2 year warranty. Give us a call... we have the guaranteed lowest prices and best tech help you will find!
Old Sep 16, 2014 | 10:04 AM
BMR Sales2's Avatar
We actually have aluminum shock spacers that allow you to raise the front easily and affordably. Here is a link to the shock spacers off our website:
http://bmrsuspension.com/index.cfm?p...&productid=506
BMR shock spacers (SA002)
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Sep 16, 2014 | 10:42 AM
ls1charged's Avatar
How much higher would it make it?
Old Sep 16, 2014 | 11:40 AM
BMR Sales2's Avatar
Each spacer will raise the car right around 1/2" and you can safely stack two of them. You will just need to make sure you get the correct length Grade 8 hardware to bolt the shocks back down the lower a-arm with the spacers.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Sep 16, 2014 | 01:30 PM
smitty2919's Avatar
Different springs are an option lol.
Old Sep 17, 2014 | 03:45 PM
Midnight02's Avatar
I needed a little more clearance and went with these in the front. Simple, cost effective solution. Be mindful of getting the right hardware if you stack a pair of them on top of each other.
Went with a 1" coil spacer in the rear....another simple, cheap fix. LMK if you need a link to those.
Old Sep 18, 2014 | 10:03 AM
ls1charged's Avatar
Anybody know what size bolt that is? Is it a M12x1.75"... So I would need a M12x2.75" at least?
Old Sep 18, 2014 | 11:59 AM
layout catalog shows M10x1.50x75(3"). 10.9 grade.
