Alignment issue
Old Oct 6, 2014 | 07:12 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default Alignment issue
Okay, So shop tells me my alignment is dead on, although, the inner shoulder of the tire is wearing more on the passenger front. Stupid goodyear told me to buy new tires and have the alignment check after that b/c my tires are getting worn... fuckwads...
Driver side tire, even wear. Car also seems to pull to the left even going up the crown of the road instead of pulling to the right to the shoulder...
Please help. I know I am slightly dog tracking due to rear suspension set up, but not out of the norm bad = still in the green zone.
Thanks in advance!
Old Oct 6, 2014 | 07:52 PM
Corvett z07's Avatar
A great thing to do is to check your alignment specs yourself, get a printout of your alignment of your car at the shop that did your alignment and see if it is within spec. I know you've heard this countless times but check for consistent tire pressure for your tires too.
Like you said too, your not centered rear suspension shouldn't hurt your front alignment, except your thrust angle, which should be on the printout sheet also.
Old Oct 12, 2014 | 05:11 PM
i got the print out and everything is in the green.
Old Oct 13, 2014 | 05:14 PM
leadfoot4's Avatar
Can you post the numbers?
