ABS Module leaking from black plug
Old Nov 21, 2014 | 07:51 PM
bigike's Avatar
Default ABS Module leaking from black plug
I installed a 3 channel diff in my 4 channel car, couldn't get ABS to work so i swapped the 4 channel back in. Went to bleed the brakes and i'm not getting anything to the back yet, and there was a masive sucking sound at the ABS module. There was a large leak there.
I've turned the car one trying to cycle the ABS and this didn't fix it.
The car sat jacked up in the rear for 2 months while i was offshore. Is this a check valve or a known replaceable part? Been raining, will remove the cover and check out the leak.
Thanks, Jay
Old Nov 22, 2014 | 07:37 AM
EDS01SS's Avatar
the abs module needs to be activated to bleed it. this can only be done by using a tech 2 scan tool. There are some folks on here that say it can be done by spinning the wheels to activate the abs but i have never tried it like that so I can't verify. search bleeding brakes on here and you will find what I'm talking about.
Old Nov 22, 2014 | 10:11 AM
bigike's Avatar
Is that why it's leaking from that plug?
Old Nov 24, 2014 | 02:34 PM
bigike's Avatar
Is this a symptom of the abs needing to be bleed?
Old Jul 14, 2018 | 10:07 PM
M4N14C's Avatar
Bump.
Mine just started leaking from that back plug pretty bad too. Stock unit. Does that just mean it needs to be bled?
Old Jul 26, 2018 | 06:16 AM
Floorman279's Avatar
Not to hijack. But if either of u figure out the module is no goof I'm selling a used 4 channel one
Old Apr 22, 2019 | 07:22 PM
kookamunga's Avatar
I think it needs to be replaced since I don't think its serviceable. mine just started doing this the other day. eventually leading to a total loss of brakes GM parts doesn't list a TCS pump so it eBay time I guess. boo
