Shocks struts and spring replacement
) strut is now more commonly used because it's cheaper and doesn't require as many parts as a SLA design.Struts are called struts because they hold the weight of the car and they control the oscillation of the bounce of the car, they are what you say a strut/shock combo. Try removing the springs from a 4th gen camaro and see if your "strut" holds up the front end of your car
All in all, the 4th gens double wishbone/SLA design is quote on quote "better" than the strut style suspension. The SLA design gives slightly more negative camber when taking corners which means the tire contact patch stays larger and more planted than the strut design, but that doesn't mean that it's the way to go either. Strut styles, like the 5th gen, are very well manipulated to handle corners and are track proven (z28 nürburgring
