lower control arms
Old Jan 9, 2015 | 11:10 PM
trey0153's Avatar
Default lower control arms
if i get the relocation brackets do i have to get the adj control arms or will the non adj ones still work?
Old Jan 10, 2015 | 06:46 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
LCA relos don't change the location of the rearend/wheels in the wheel wells. Factory OEM LCAs' and aftermarket non-adjustable LCAs' work fine.
Old Jan 10, 2015 | 01:44 PM
UMI Tech's Avatar
We sell a ton of relo's with standard lower arms.
If your car is tweaked, if you have an aftermarket housing, etc you can go adjustable.
-- Ramey
Old Jan 12, 2015 | 09:29 AM
MidwestChassis2's Avatar
Like stated you don't have to but any time you can add adjustment to your suspension items the better off you are for aligning/squaring up the vehicle..
