Suspension/tire problems
There was no noticeable vibration or sounds.
Today I went to jack up the car ( 2000 Pontiac Trans Am) and noticed the rear passenger side was about 1-1/2" lower ( because I could not fit my jack under) than the rear driver side.
I first checked all the lug nuts, and everything was tight. The wheel looked to be on straight etc.
When I went to jack the car on the frame, the wheel did not want to come up with it. I had to jack the rear side really high to get the wheel off the ground about 1/2"
any suggestions on what to look at or need to replace... rear shock? - still the original ( about 109K miles)
any suggestions or confirmations would be appreciated.
and I did follow my wife driving to verify that the wheel was wobbling a little.
if it is a shock, would that cause the wheel to have a slight wobble ?
The real question here is the 1 1/2inch lower on one side. Sway bar endlinks come to mind, but that wouldn't make it 1 1/2 inch difference on one side vs. the other...
