alignment problems
Old Feb 19, 2015 | 02:18 AM
lovethyGM's Avatar
Default alignment problems
Bilstein SLPs lowering package with spoon lCA and the mechanic can't get the alignment correct is there something I got to do....or is he just a retard....
Old Feb 19, 2015 | 06:21 PM
1BAD02WS6's Avatar
What's not correct about the alignment?
Old Feb 20, 2015 | 12:56 AM
lovethyGM's Avatar
I think they were saying it was the toe
Old Feb 20, 2015 | 10:15 AM
smitty2919's Avatar
What is "correct"?
You want it within factory specs of what they have in their computer?
IMO if you spent the money on suspension parts for lowering/handling then you should research a proper handling alignment. Bring it to them and have them follow it.
Old Feb 20, 2015 | 10:22 AM
1BAD02WS6's Avatar
If they could not get the toe in specs... Go some where else. I'm guessing the "spohn LCA" is the front LCAs? Are they adjustable?
Old Feb 20, 2015 | 11:45 AM
leadfoot4's Avatar
You need to be a little more specific, as to what isn't "correct"....
Old Feb 20, 2015 | 11:49 AM
lovethyGM's Avatar
Yea fully
Old Feb 20, 2015 | 11:53 AM
lovethyGM's Avatar
-5.00 on the toe and I'm not sure about the rest gotta find the paper and yes I want them some were close to factory they said cause of the aftermarket parts they can't it simple impossible...I think there bullshiting ...
Old Feb 20, 2015 | 11:54 AM
lovethyGM's Avatar
I just want some output from people that been doing this for a while...
Old Feb 20, 2015 | 12:19 PM
AnotherWs6's Avatar
You actually want their input
Old Feb 21, 2015 | 07:55 AM
leadfoot4's Avatar
Since your toe should be around 0.00-.02*, a (-)5.00* on a toe setting, is about 2 full inches of toe out! You should be able to see THAT from 20 feet away...
(OR, you're reading caster, instead of toe)
I can see an "average Joe" alignment shop having possible issues setting caster/camber on a car with aftermarket parts, and/or an extremely low ride height, but if they can't set the toe-in, something is seriously wrong, and unless you've installed some wacky parts on the car, or installed something incorrectly, the problem is with the guy trying to adjust the car....
