Castle nut question
Old Mar 13, 2015 | 08:23 PM
brewcrew011's Avatar
Default Castle nut question
So while taking the spindle arm off the upper ball joint, I broke the cotter pin off in the hole. So without thinking, I used a screwdriver to try to punch out the hole, hit it too hard and it broke off in the hole. Tried drilling it out but started to mangle the thing so now I need a new plan. Thinking a different nut with Loctite or a nylon insert lock nut? What's the best alternative?
Old Mar 13, 2015 | 08:27 PM
fastassls1maro's Avatar
replace the ball joint, there like 25$ and its safer that way
Old Mar 13, 2015 | 08:45 PM
Don't have the tools or anything like that to replace a ball joint. I'm leaning toward the nylon locking nut, couldn't see that backing off or anything like that
Old Mar 13, 2015 | 09:13 PM
Zmg00camaross's Avatar
Nylon nut would be fine. Also seen several castle nuts without cotter pins hold for years! So up to with what your comfortable with.
Old Mar 13, 2015 | 10:55 PM
guppymech's Avatar
If you're going the self locking nut route use a all steel self locking nut, the damaged area on the stud will ruin the nylon insert on a nylon lock nut. Any good hardware store will have full steel self locking nuts.
Old Mar 15, 2015 | 09:33 AM
1981TA's Avatar
Most auto parts stores (advanced, auto zone, etc) will "rent" tools like you need for free, once you return them. I'd go that route and replace the ball joint while you have the chance.
Old Mar 15, 2015 | 07:24 PM
Ended up replacing the ball joint, couldn't get anything to thread on to the stud. All done now
