Spohn torque arm play
Old May 11, 2015 | 07:37 AM
bufmatmuslepants's Avatar
Default Spohn torque arm play
Last time I was at the track, the only time on this Spohn torque arm, I had some clunking. I had it parked and crawled under the car and had my buddy rock the car forward and back with the e brake on and noticed it had some play from the actual torque arm to the mount on the axle housing. Like the hole for the pinion adjuster was loose, or the bolt was a hair too small. Anyone have this happen and what did you do? I bet if this is just "how it is" that multiple hard launches with this play could cause all of the Spohn torque arm failures I keep seeing. I will go back to a long style BMR if I can't fix it, this is frustrating.
