which FRONT lower control arms?
long story short...bushings shot. Read all about nightmare of replacing bushings. So just get new arms right? No go, cant find em except used or shitty aftermarket.
Looks like im going with UMI, BMR, etc.
Question is...which ones? This is a street only car and will be used as such. Which arms are the best for DD? My main concern is longevity and quiet bushings. Most of these seem track oriented.
another issue is I will be installing the arms at work and don't have a press....I wont have any downtime to get access to a press. I want to just do an arm swap out. much less labor and possible issues.
I guess im saying my mind is pretty made up....I just don't know what performance aftermarket set would be the best for my DD. Im still unsure on the differences of boxed vs. tubular
If you're dead set on going completely aftermarket, and you DD the car, I'd say UMI boxed is the best option. They are stronger and I believe UMI rates them for street use. I wouldn't feel super confident driving a tubular front end over a road littered with potholes.
The stock front lower control arms would be more work if you got a second pair and had a shop replace the bushings in it, but, yes there's a big but here, you would save a large handful of money and it would be the most forgiving ride with added benefits of lessening noise on the street vs the aftermarket control arms.
If aftermarket, I'd lean towards boxed as well
