E-brake/backing plate question
Old Jun 9, 2015 | 12:46 AM
Skeet Skeet's Avatar
Default E-brake/backing plate question
Does anybody know if you can replace the e-brake that's is attached to the backing plates? My rear axle bearing seals were leaking for quite some time so I replaced my work out 10 bolt with a 9" and am re-using my backing plates but the e-brake is soaked in gear oil. I need to replace the pads and the rubber gromit piece that surrounds the lever for the e-brake. If I could get a part number or a link to purchase them I would greatly appreciate it. I've searched for them but can't find them or if you can replace them.
Old Jun 9, 2015 | 10:10 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
I have all of it available... give me a call!
Old Jun 10, 2015 | 12:34 AM
Ok sounds good, I'll be in touch shortly. Also do you sell sway bar end links? I'm going to need them also so I can wrap up the wrest of the items I need to install my new 9"
Old Jun 10, 2015 | 08:48 AM
ssvert99's Avatar
We sure do!
