SLP line lock help
Old Jul 1, 2015 | 03:45 PM
2000 TA owner's Avatar
Default SLP line lock help
is it needed to run the wire all the way around the car like the directions say or can i run it straight thru the drivers side to the selenoid or is it they dont wont the wire wrapped up that might cause interference any help would be appreciated
Old Jul 1, 2015 | 08:50 PM
mackdaddy66's Avatar
the directions I had when I installed mine had me go through the dash on the drivers side, shouldn't matter as long as it gets its voltage it won't care how you routed the wire. I probed and slid it right along side my hood release cable
Old Jul 1, 2015 | 08:52 PM
I had a tougher time with getting their pre formed lines to not leak... the ones I double flared were not so pretty looking but sealed first time no problems
Old Jul 1, 2015 | 08:56 PM
mine is an lt1 car, but that solenoid has no idea what make or model of car it is going in... route it how you feel comfortable, just make sure you are not routing it into harms way and make sure and use the fuse for just in case it rubs through or the insulation gets damaged in some way... little wd40 helps too for sliding through the grommet
Old Jul 2, 2015 | 09:59 AM
Stuinkuwait's Avatar
I ran my wire thru the trans tunnel so I could mount it on the shifter. worked out well.
Old Jul 2, 2015 | 04:14 PM
thanks everyone thats what I thought just wanted to make sure I wasnt missing something
