Problems with new pads and rotors
Old Jul 17, 2015 | 07:23 PM
Kevin_Ls1's Avatar
Default Problems with new pads and rotors
I have a 99 z28 and I bought four new drilled and slotted rotors that came with pads.. Installed them and car stops great... Only issue I've noticed is the rear driver side rotor isn't wearing evenly... From the edge about less than a half inch it's shiny and the rest of the rotor isn't broken in.. I took it out again to investigate.. I saw the the bad for the front part of that rear rotor isn't wearing evenly, only half of the pad is breaking in, while the other half isn't, meaning it must not be flush up against the rotor as the brake is applied... The caliper seemed ok as I was able to compress it with the brake compressor tool.. Is there anything I need to look for or anything to fix this? Thanks everyone for any help.. Greatly appreciate it
Old Jul 17, 2015 | 09:32 PM
1981TA's Avatar
binding slider pin? Uneven bracket-to-backing plate surface (bent, loose or crap stuck between)?
Old Jul 18, 2015 | 07:02 PM
Stan1911's Avatar
Slider pin is my guess also, grease dries and binds. Throughly clean inside the pin area and the pins then re-grease, it is amazing how much more movement you get when they are working properly.
Old Jul 22, 2015 | 12:30 PM
blkbird's Avatar
My issues was a bent backing plate.
