Mwc front end kits
Old Aug 21, 2015 | 01:39 PM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
Default Mwc front end kits
As always our prices are the best and the quality is the highest you will find, MWC is now offering all of our front end packages at a even deeper discount.
Stage 1= Mild steel k-member and full adjustable lowers
Stage 2= K-member, full adjustable uppers and lowers
Add a manual rack kit(rack, bumpsteer spacers, needle bearing jointed steering shaft) to Stage 1 or 2 for only 425.00!
Stage 3= K-member, full adjustable uppers and lowers, Viking d/a shock package
Stage 4= k-member, full adjustable uppers and lowers, manual steering rack-bumpsteer kit-stering shaft, Viking d/a shock package
Stage 5= MWC full race front end pkg. Chromoly k-member, 2pc cm lowers, cm adj uppers, cm spindles, Strange Pro brakes, Viking d/a shock pkg. This is the same package that the record setting 6 second Ohio Boys use, as well as others like Brian Black, Ray Litz, Andy Essary, and Eddie Krawiec just to name a few.
Menscer, Afco, and Strange shocks are available with any of the packages.
We also offer a race style 2pc adjustable lower arm for the oem spindles on stages 1-4. This option adds 50.00 to the price and requires the use of a 6" wide or less wheel. This option includes the k-member with single hole style brackets that eliminate the slotted style hole for the lower arms that commonly have issues keeping the alignment setting in place w/ aftermarket k-members.
These are shipped prices, and we can accommodate other customization if need be for those needing different options. As always MWC GUARANTEES the lowest prices and highest quality. If you find a better deal on similar components we will beat it!
Also all our K-members accept up to a 5" down pipe for your turbo applications for no extra charge.
