Rear end question
Old Sep 6, 2015 | 03:12 AM
z28boycali's Avatar
Default Rear end question
My 00 SS rear end unfortunately going out. Due to my SS being a 6 speed I'm struggling to find one on Craigslist from a manual Camaro.
However I did find one low miles from an automatic z28, I am aware about the gear difference. But if I was to purchase would there be a way to upgrade everything so it would work on my SS without a problem?
Old Sep 6, 2015 | 03:23 AM
Burken01's Avatar
Make sure it's the proper rear end as far as 3 or 4 channel..
If your car has traction control aka "asr" button above the radio then you need a 4 channel rear end if you want to keep abs and traction control.
If you don't have the traction control asr button then you have a 3 channel rear end and will want another 3 channel rear end so ABS will still work..
If you don't care if you have abs or not then it doesn't matter which rear end you get..
Being that it's an automatic rear end in the z28 that you are looking at it will either have 2.73 gears or 3.23
I would not run 2.73's in a 6 speed car if it were me.. 3.23 would work better
In any case after the install you will need the computer flashed for the new gear ratio so the speedometer reads correctly
Old Sep 6, 2015 | 12:58 PM
z28boycali's Avatar
man that sounds like trouble after trouble! I need a solution to this .......
Old Sep 6, 2015 | 02:49 PM
Burken01's Avatar
It's pretty straight forward after you locate the proper rear end!
Old Sep 7, 2015 | 06:51 AM
leadfoot4's Avatar
It's not really trouble, there are FAR worse problems. You just have to do a little homework....
Old Sep 8, 2015 | 08:24 AM
MidwestChassis2's Avatar
Your best option would be to ordering an aftermarket rear end. Many different ones to choose from and we can help you with any questions on all of the available options.
