99 fbody leaning
Old Sep 17, 2015 | 08:44 PM
xdanny510x's Avatar
Default 99 fbody leaning
I got a question.. maybe someone can help me out here.. i recently added rear drag shocks to my camaro and well i just noticed its leaning alot to the left.. front and rear ! Could this be a sign of bad springs or did i mess up on the shocks... they are lake wood 50/50 drags
Old Sep 18, 2015 | 02:00 AM
Burken01's Avatar
Did the springs twist in the rear when you had it jacked up?
Old Sep 18, 2015 | 09:09 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
If everything is in it's correct position, then the shocks *should* not be able to affect ride heights. A shock simply controls the dampening or speed of the suspension within it's travel, should never affect the ride heights. Ride height is controlled by the spring length, rate, and mount positions.
The best thing to do is go with a 4 corner coil-over setup that allows for adjustable ride heights, spring rates, and shock valving. MWC has great prices and several choice of shock brands to suit your needs!
