bolt on subframes
Old Sep 20, 2015 | 06:27 AM
Viper's Avatar
Default bolt on subframes
Slight issue with my LT1. The UMI set comes with a plate you are supposed to slide in the frame in the front. The issue is I can't get the plate in the frame. Any ideas as to what people do?
Old Sep 21, 2015 | 06:56 AM
Viper's Avatar
I imagine I can cut the plate in half to slide it in the frame.
Old Sep 21, 2015 | 07:13 AM
UMI Sales's Avatar
Is the area collapsed from someone using a jack? I've never heard of this being an issue... Can you post pictures of that part of your frame and the issue you are having?
Old Sep 21, 2015 | 07:18 AM
Viper's Avatar
One side is, the other is fine. I'll post pictures and thanks! Like I said perhaps cutting the bar in half will work as it would allow me to slide it in the hole as opposed to the opening at the back of the rail.
Old Sep 21, 2015 | 08:12 AM
UMI Performance's Avatar
Like mentioned, most likely it is collapsed from jacking. I bet you could pry the hole open to get it in there.
Old Sep 21, 2015 | 11:13 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
a good sized pry bar will work,also a carbide bit die grinder to open the hole in the places you need clearance.
