Need some dimensions please
Old Nov 10, 2015 | 08:28 PM
schmendog's Avatar
Default Need some dimensions please
Hopefully someone willing can help me out here.
I'm fabricating brackets to put this 9 inch fab housing under my GTO. Some of the suspension components I'm using are F-body parts. Does anyone know, or can someone measure for me the width of inside of the Lower control arm boxes? I could just make it the same width as the bushings, but I don't know how tight the clearance is, and Id like it to be exact.
Thanks!
Old Nov 10, 2015 | 08:31 PM
schmendog's Avatar
Also, trying to find the diameter of the hole that the mounting bolt passes through.
Old Nov 11, 2015 | 07:28 AM
UMI Sales's Avatar
The holes are generally right around .500". It's a 12mm bolt, so there's clearance built in. The width would be hard to measure since they're usually smashed in some, but the sleeve should be 2.400".... With that said, I would aim for 2.450". Hope that helps!
Old Nov 11, 2015 | 07:42 AM
schmendog's Avatar
Perfect, Thanks UMI.... Should have just called you since I have all my parts from you guys.
Old Nov 11, 2015 | 08:01 AM
UMI Sales's Avatar
If you ever need anything just give us a call.
Craig
