Winter project time
Old Dec 7, 2015 | 03:39 PM
5.7stroker's Avatar
Default Winter project time
A few parts came in. Time to get the party started.
I'd like to thank the guys at Midwest Chassis, Gil at 6litereaterdesigns, and Mike at ws6project for giving me something productive to do this winter.
Viking double adj coil over kit, new strut mounts
ROTO-PKG cross drilled/slotted rotors
Hawk Brake pads HB249F.575 & HB250F.653
CME valence, tips, I-pipe, mufflers, DHM electric cutouts
AC compressor, Evap tube, condenser, drier, pressure lines
PST aluminum 3.5 driveshaft
Old Dec 7, 2015 | 04:03 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
Thanks for the order you have some good looking stuff there!
Now that you have some good shocks your suspension will show what it is(or isn't) made of. Give us a call you know we will be glad to help you out!
Old Apr 21, 2016 | 05:27 PM
5.7stroker's Avatar
Current mods:
Engine
Lingenfelter 346 shortblock (LPELS1LS6SB)
Mahle PowerPak Pistons LS1340905F04
PRC 5.3 stage 2.5 heads
Comp Cam 233/240 .618/.589 LSA111+3
Fast 92 Intake
PTM 92mm throttle body
SLP lid
SSRA
ARP Head Bolts
7.275 pushrods
BTR Truions
Morel lifters
BTR Titanium valve springs
MSD 85mm spark plug wires 46-234-2503
ASP Crank pulley
Accessory Belt for Crank Pulley 19-760K6
AC belt for ASP pulley 19-K040378
MM Catch Can
BR7EF spark plugs
N2O
NOS progressive mini controller
Nitrous Outlet 98-02 F-body FAST 92mm plate kit
Nitrous Outlet 10 lb x-series bottle
Nitrous Outlet stage 2 accessory kit
Nitrous Outlet Remote Bottle Opener
Emblempros 6 button cig lighter switch plate
Custom center console dual gauge, switch plate
Innovate LC-2 wideband and gauge
Exhaust
Speed Engineering Headers and Y pipe
Walker 54064 / 53061
6LE Designs CME Exhaust tips and elbows
Dynomax muffler #17227
DMH electric cutout in the i pipe
Fuel
Deatchwerks 18u-01-0039-8 (flow 46.6# at 58 PSI)
Racetronix pump with hotwire kit
FAST Fuel rails
Nitrous Outlet stand alone fuel system
Transmission
Performabuilt Stage 2 4l60e
Edge 4000 stall converter
Trans cooler B&M 70264 dope style
B&M Flexplate
Suspension
Viking double adj coil over kit A206-350K, C213-R, 14DP150
UMI Kmbmer and Arms FBS002
UMI adj rear lower control arms
MWC Tunnel mount torque arm and double drop crossmemer
Spohn Rear Lower Control Arm Relocation Brackets #210-S
Spohn drag sway bar #921
Adjustable Spohn Panhard bar #104
BMR Weld in SubFrame Connectors SFC001
Prothane Motor mounts 7-512
UMI Strut tower brace 2005-R
Moog K6516 Front Upper Strut Mount Kit
Moog K6573 Macphereson Strut Mount Assembly (qty=2)
Moog K6517 Front Upper Strut Mount Kit
Acdelco 22174970 Transmission Mount
Tie Rod Ends MOOG EV260 and MOOG ES3238RL
Rear End
Dana Strange S60 rear end with 4.10 gears, s-trac, 35 spline, 3/4 reduced on each side
Wheels
245/45/17 Michelin Pilot
275/50/15 Mickey Thompson e.t. streets
Race Star 15x10 (7.25) backspacing
Race Star 17x9.5 (92-795253DP)
Brakes
Upgraded Cross Drilled & Slotted Brakes (ROTO-PKG ws6project.com)
Hawks HP Pads HB249F.575 & HB250F.653
Appearance
White faced gauges
20% tint
RK sport clear corner lights
Stull billet grille 36-0180
68 SS grill emblem
Polished aluminum Camaro rear fill in letters
Silver outlined SS emblems with black fill (emblempros)
Halo LED headlights
6LE designs CME valence
N2O, trans, fuel pressure, oil pressure glow shift gauges and triple pillar
6LE designs T-Top shades
Custom cig lighter switch panel emblem pros
Custom center console N2O panel
Embempros AC billet cap
Stainless battery cover
Stainless Brake Master Cylinder Cover
Stainless 2Pc Fuse box cover
Stainless steel engine dressup bolt kit
Billet coolant cap - hawks
Billet radiator cap - haws
Billet windshied washer cap - hawks
Billet brake res cap - hawks
Billet oil cap - hawks
Billet ps cap - hawks
