Squeaky-squeaky!!
Old Dec 10, 2015 | 12:41 PM
big_g's Avatar
Default Squeaky-squeaky!!
So I'm kind of a noob with suspension stuff. But my car creaks like grandma jumping on an old trampoline with even the slightest movement. Both sides of the car in the rear. As far as I know it is all original parts. 2000 WS6 with 66k miles. It is my DD. I'm guessing it is my LCA bushings. If that turns out to be the case, what is my best option for new LCA's for a "fun" DD?
I was looking at the BMR BCA001. But do I want rubber bushings for ride comfort? Thanks guys.
Old Dec 10, 2015 | 01:05 PM
1ta ls1's Avatar
Swaybar end link bushings. Very common.. I'll bet my trampoline on it.
Old Dec 10, 2015 | 01:25 PM
big_g's Avatar
Hmm, I'll check them out then. Can I just shoot some white lithium grease on em'?
Old Dec 10, 2015 | 07:54 PM
JD_AMG's Avatar
Before you go buying anything you can check a few things real easy.
Get under the car and disconnect one side of the rear LCA and swing it down, move it around with your hand and see if it makes any noise.
Another check is the swaybar bushings like already mentioned. Under the car again, unbolt the D bushings (the bushings that connect the swaybar to the rear axle) and then bounce the car with your arms and see if there is still a noise.
If its coming from the front do the same with the front swaybar and unbolt the D bushings that connect it to the body.
Old Dec 10, 2015 | 10:59 PM
SparkyJJO's Avatar
A good sign your LCA bushings are shot would be if you drop the LCA down as described above and the bushing is loose/falls out of the arm. That shouldn't happen on a good rubber bushing.
Old Dec 11, 2015 | 12:22 PM
1ta ls1's Avatar
It may, but in my experience any grease on those end link bushings will make it worse. They are a white color and get hard and rub and make a squeaky noise. I can't imagine it being LCA bushing on both sides with that mileage.
Do a search on end link bushings.. That would be my first look on an F body when it squeaks. Open the trunk and push up and down. If you got the squeaks, then it's 99% the end links.
Old Dec 12, 2015 | 07:45 PM
Silverbird01's Avatar
Any downside to replacing the poly swaybar link kits with rubber ones?
This is what squeeks on mine and it's enough to drive you crazy.
Old Dec 12, 2015 | 07:57 PM
1ta ls1's Avatar
None. I've have the poly sway bar end links for 8+ years, and still work fine. No squeaks. Actually was the first thing I replaced on my car when it had 20k miles. But it was 5 years old by then..
Old Dec 12, 2015 | 10:02 PM
NowhereFast's Avatar
I wouldn't rule that out so quick. My car used to creak from the back going up and down driveways until I replaced the LCAs and the panhard with poly/roto-joint versions. My car only has 68k on it.
A lot of times age will kill bushings too, not just mileage. The newest 4th gen is already 14 years old.
Old Dec 14, 2015 | 09:18 PM
big_g's Avatar
^^^ Yep, that squeaks (well, creaks) like crazy.
Well, its been rainy and in the 30's, so I'm not working on it this week. I did notice that the noise goes away after a few minutes of driving in the rain, which makes sense I suppose.
Old Dec 14, 2015 | 09:52 PM
UMI Tech's Avatar
Another thing to try is silicone lube spray on one joint at a time and listen for improvement.
Old Dec 17, 2015 | 04:11 PM
big_g's Avatar
Is this ok to do without jacking up the car or anything?
Old Dec 17, 2015 | 06:10 PM
JD_AMG's Avatar
Yes, actually you should ideally do it without letting the suspension hang down, so be at ride height.
Old Dec 18, 2015 | 05:47 PM
big_g's Avatar
Well, you can keep your trampoline. I crawled under there and hit everything with silicone spray and it didn't help much. So then I got my stethoscope and crawled back underneath and put it on everything as I pushed the car up and down. When I put it on the bottom swaybar end link bushings...viola! I soaked the crap out of em' with the spray but no change, they still squeaked. So I think they are totally shot.
Now, for a DD should I just replace the bushings (http://www.bmrsuspension.com/?page=p...237&superpro=0), or get the whole kit (http://umiperformance.com/catalog/in...ducts_id=291)? Not sure what difference I'd really get for a DD over stock? Besides the cool-looking red bar factor...
Old Dec 18, 2015 | 06:53 PM
JD_AMG's Avatar
Thats a much bigger bar than the stock one, for balanced handling you will want to upgrade the front bar to match that one (a 35mm front bar will be ideal), otherwise the car will oversteer quite a bit when being pushed hard.
So if you just want to get rid of the squeaks then just replace the endlinks, but if you want to improve the handling get both front (35mm) and rear (22mm) swaybars.
Old Dec 18, 2015 | 07:06 PM
big_g's Avatar
This is all I needed to know! Thank you all for your help! I'm just gonna go with the endlinks. You all rock
Old Dec 23, 2015 | 04:40 PM
big_g's Avatar
Well I replaced the endlinks with new ones (rubber ones). Still creaks just the same! I torqued down the endlinks quite a bit...maybe too much?
If I was smart I'd have checked if the creaking was gone while the endlinks were off, but alas, I'm not so smart... I'll try the "D" bushings next I guess.
Old Dec 23, 2015 | 06:38 PM
Corvett z07's Avatar
I didn't know endlinks squeaked... oh well it was worth a shot.
The sway bar D bushings are the most likely thing to squeak, my poly sway bar bushings used to squeak, I then greased them and the squeaks went away. Rubber is less likely to squeak than poly, but that doesn't mean it's impossible for them to not squeak either
Old Dec 23, 2015 | 09:24 PM
big_g's Avatar
Ok, well at least all these things are cheap and easy. My stethoscope sure seemed to indicate the endlinks though. What am I supposed to torque the endlinks to? I aimed for 16ft/lbs on the first one, but it never clicked and the bushings looked pretty squished...
Old Dec 23, 2015 | 10:50 PM
Badazz 97 TA's Avatar
You can't really torque them because you will just squish them like you experienced until you run out of thread. You just want them to compress just a little so there is no slack in the endlink.
Loosen them up.
