LCA install
Old Mar 11, 2016 | 02:26 PM
Austinma62's Avatar
Default LCA install
Just a quick question. I am wanting to swap lower control arms on my car but I can't unload my suspension all the way since I'm running dual exhaust underneath the axle. My question is can I replace my lower control arms with the suspension under load?
Old Mar 11, 2016 | 03:21 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Yes,you'll probably have to unload it slightly to get some movement to get bolt line-up as when the arm is removed,things tend to shift a bit. Do one side at a time as when if the entire rearend shifts,hole line-up get even more difficult.
