spring isolator
Old Mar 15, 2016 | 07:39 PM
hoonigann's Avatar
Default spring isolator
Hi all. So after 61k, my shocks and suspension has seen better days. I plan on throwing on konis and stanos springs once i have the funds. but for now i thought about just replacing the rear spring isolator since i feel the most of the bumps from the rear. has anyone replaced the isolators or knows how much it difference it actually makes? Thanks!
Old Mar 16, 2016 | 07:14 AM
matt1289's Avatar
My rear spring isolators were fine after 125k miles. I just replaced my suspension with Koni/strano springs.
It's likely a combination of 3 things for you. Worn out shocks, bump stops worn out or completely gone, and sagging worn out springs.
I put the rear Koni to 1/2 trun from full soft with Strano 's springs and new bump stops. Night and day better over the bumps.
Old Mar 16, 2016 | 12:45 PM
jaxcam02's Avatar
I second that your rear spring isolators should be fine. I just did a complete suspension rebuild and and reused my rear isolators with no effects. The issue you are facing is most likely the springs/shocks and bumpstops.
Old Mar 16, 2016 | 03:26 PM
Corvett z07's Avatar
X2
Spring isolators usually don't go out on these cars, if at all. I'd check bumpstops first to see if they're still intact.
Old Mar 16, 2016 | 05:02 PM
hoonigann's Avatar
Ya it's bump stops. Ordered some new ones
