UMI torque arm issue
Old Mar 26, 2016 | 02:45 PM
deegan26's Avatar
Default UMI torque arm issue
Alright, so I'm installing some goodies and included in those are long tubes, with 3 inch ORY by TSP, UMI torque arm relocation cross member, full lengrh adjustable torque arm and poly motor and trans mounts. My issue is that when installing the Y pipe it is hitting the torque arm. The torque arm also looks like it's binding in the bushing. I'm also lowered on strano springs. I'm also not 100% sure if I installed the bushing on the relocation mount correctly with the shim. Did I install everything right? What can I try to get the clearance needed?
http://imgur.com/Z6Vk1yL
http://imgur.com/jZ1NHlX
http://imgur.com/QNE8nMD
http://imgur.com/C4fuQUq
http://imgur.com/R61hq7E
http://imgur.com/2qhBpH2
Old Mar 26, 2016 | 07:07 PM
JD_AMG's Avatar
Cant you raise the torque arm higher up on the mount?
Old Mar 26, 2016 | 09:17 PM
klinznilk's Avatar
Raise arm as stated above and readjust pinion. That is what I had to do with my BMR
Old Mar 31, 2016 | 03:53 PM
UMI Performance's Avatar
Yes, go up one hole. Looks like the rear end isn't allow the arm to rotate downward. But up if you can get it is better.
If you let the car settle on the ground with suspension loaded it will unbind from the bushing.
I hope that helps,
Ryan
