4th gen 9" installation help needed
I got a question. I just put a 9" in my 4th gen car and still awaiting parts to complete trans swap to attach Torque arm. I ran into someone else who did the same and is struggleing with set up. viewing from the rear of his car the driveshaft is on an angle so that rear of it is toward passanger side, and then his torque arm is opposite. rear is angled toward drivers side. so my question: is the 9" housing fabricated so that the center section of housing is offset toward drivers side of car to compensate so the third member yoke (which on the 9" is offset) is actually centered in tunnel when overall housing is centered?hope this make sense. just hoping when I get to this point I don't have the same struggles. this other guy is so frustrated that he's ready to pull the 9". pic is of other guys car
This is correct, a stamped 9" housing utilizing a stock style mounting torque arm will move the torque arm to the passenger side and the driveshaft over to the passenger side to make room for it all to work. Once it is said and done the torque arm makes contact with the drivers side floor board and in some instances making driveshaft loop fitment an issue.
We can get away with this because our torque arm does not use a stock style mounting torque arm.
