Strut and spring questions
Old May 2, 2016 | 08:51 PM
ThatRedLs1's Avatar
Default Strut and spring questions
I am trying to fit up my sportlines to some struts on my 98 trans am, and they did not fit well on my monroe struts. The spring bucket was flat, and the spring kept sliding around, and sat crooked. So, i was going to try kyb struts. I was wondering if these struts, http://www.summitracing.com/parts/ky...w/make/pontiac, are compatable with this coil spring isolator, http://www.summitracing.com/parts/mo...model/firebird. (I just need the rubber part, because I am pretty sure the struts dont come with it.)
Old May 2, 2016 | 09:44 PM
SparkyJJO's Avatar
Should be, most shocks are. That's probably why they didn't fit your Monroes because you didn't have a lower spring seat on the perch/bucket.
That said, the Monroes would totally suck with those Sportlines anyway. Not sure on the KYBs.
Old May 4, 2016 | 07:19 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
I used the Bilstein B6 with the stock springs and seats without any problems.
Old May 4, 2016 | 08:41 PM
Darth_V8r's Avatar
Moderator
I did this too which was great until the tubular K. With reduced weight, it's no Bueno.
