Gremlin?
Old Oct 23, 2016 | 01:30 PM
LS1121's Avatar
Default Gremlin?
OK so I have one of these elusive upper control are support seals with a part# on it but I cannot seem to source it. How bout someone else giving it a shot?
The Right side ends in 78.
Old Oct 25, 2016 | 05:39 PM
LS1121's Avatar
wow 189 views and no response. There is the part#, cannot anyone find this part? I looked extensively but no luck. Mine are good but I was just trying to help others.
Old Oct 25, 2016 | 06:44 PM
99SSJarhead's Avatar
No one makes them anymore. GM discontinued the part and now you'll only find used ones on ebay. 93-02 Camaro Firebird Front Upper Control Arm Mount Rubber Bushing Isolator.
Best to clean and paint the area and probably coat with some grease if missing.
Old Oct 26, 2016 | 04:36 PM
LS1121's Avatar
nobody...... I find that hard to believe, not saying you're not correct but I just find it hard to believe with all these cars out there...........
Old Oct 26, 2016 | 05:11 PM
And yet you've found 0 even with the serial number, as had everyone else who have posted this same question over the years. You'd think on the largest 4th gen site someone would have tracked down a supplier by now. But the common response to this is to either track down a used one or just run without since it is the other one, the coil spring isolator bushing, that is the important one.
They aren't really a failure part and as such are probably rarely ever seen by most people. As such there isn't much incentive for a company to produce them.
Old Oct 26, 2016 | 07:33 PM
LS1121's Avatar
I'm not doubting you so please don't take it the wrong way. It's just as popular as these cars are, well you know.........
