Smaller caliper
Old Jun 22, 2017 | 09:19 AM
dw456post's Avatar
Default Smaller caliper
Is there a smaller caliper that bolts on in place of a 2002 Camaro caliper for 15" wheels?
Old Jun 22, 2017 | 11:36 PM
jlrz28's Avatar
10 Second Fun Car
Front or rear? Front I used the Wilwood kit which has been great. The rear is a little more difficult if your using oem style flanges.
Old Jun 23, 2017 | 05:52 AM
dw456post's Avatar
I should have put that info in the post. It is the rear. It's an 8.8 Ford rear with Camaro brakes. I didn't want to grind so much off the calipers to make the wheel fit. Unfortunately, I bought some weld wheels before I figured out the problem. I was hoping some other year of caliper would bolt on and clear the wheels.
Old Jun 26, 2017 | 09:23 AM
dw456post's Avatar
I gave in and got out the angle grinder. It took about 30 minutes each to grind off enough the calipers to clear the wheels. It would have been quicker if I didn't have to put down the grinder several times to rest my arms.
