which brake for this price
Old Jun 29, 2004 | 10:14 AM
malchevy72's Avatar
Default which brake for this price
i am looking to spend between 400-450 on a front brake up grade with better performance. anyone have any suggestions they can give me . i would also like to upgrade the calippers with that price but if not possilbe i will do later.
Old Jun 29, 2004 | 12:15 PM
Z28camaroLS1's Avatar
Blank brembo rotors oem size for $87 each x 2 = $174
Set of Hawk HPS brake pads for $85
You can get these on www.tirerack.com
Hope this helps.
Old Jun 29, 2004 | 04:20 PM
CaptUSA's Avatar
Those would make fine replacement rotors & pads, but would it be much of a performance gain? I was under the impression that in the world of rotors, size always matters? The Hawks HPS's will help though.
Old Jun 29, 2004 | 05:30 PM
felton316's Avatar
You could add the $250 for the LG C5 brackets to Z28camaroLS1's quote. And use the bigger C5 brembo blanks and HPS brake pads. You should still be under budget. Maybe even get some ATE super Blue brake fluid, add another $10 to the quote.
So now you will have:
LG C5 caliper brakets
Brembo C5 OE blanks (rotors)
Hawk HPS pads
ATE brake fluid
Old Jun 29, 2004 | 10:23 PM
malchevy72's Avatar
hey those brackets will fit on my camaro SS or will i have to do some slicing and dicing? and where do u find those brackets?
Old Jun 30, 2004 | 12:19 PM
felton316's Avatar
LG motorsports------->
sells those brackets. they should be a direct bolt on to 98-02 cars, the 93-97's might need a little cutting, but I'm not too sure about that. You will need to give them a call.
Old Jun 30, 2004 | 12:55 PM
JohnnyZ28's Avatar
I was going to say go with some slotted / cross drilled rotors. We have a place locally that will take the rotors, in this case Brembo's would be nice, and they cryo freeze them and are heat treated. Then for an extra $80 a pair the cross-drill and slot them.
That would give you high strength rotors that will not warp, and you'll stop on a dime.
I went with the Wilwood brakes and they are nice, but I lost my ABS and its ******* with my traction control systems.
Old Jul 2, 2004 | 03:10 AM
Are you talking about the front Wilwood 6 pistons caliper brake kit for $1400?
Why did you lost your ABS and what's the matter with your traction control system?
