Drivers side rear caliper binding
Old Sep 2, 2017 | 05:03 PM
TheNutDriver's Avatar
Default Drivers side rear caliper binding
My drivers side rear caliper is binding. Now I've not had chance to remove anything yet to take a look, but is it worth messing with it or is it best to replace the whole thing for saying how cheap they are from rock auto?
Any usual suspects with these calipers which is a quick fix?
Old Sep 3, 2017 | 09:31 PM
wssix99's Avatar
Save the manuals!
First check for seized caliper slider pins. If they don't slide, then you may just have to lube the pings or replace the caliper bracket. (Sometimes the sleeves in the bracket will flat-spot and lock up the pins.)
If they are good and your caliper piston won't retract, then it's time for a reman caliper.
Old Sep 15, 2017 | 06:26 PM
Thanks for the reply. It was the slider pins. All ok now.
