Spohn rack and pinion
Old Oct 20, 2017 | 11:30 PM
Steven Bellomy's Avatar
Default Spohn rack and pinion
I have a sphon rack and pinion on my 1995 camaro. Chamber set at -1. Caster at +8. With the rack centered. The passenger toe adjustment has plenty of adjustment but the driver side is toe out very bad with tie rod adjuster screwed in tight
Old Oct 22, 2017 | 10:23 AM
Z28SteveA4's Avatar
Are you saying you don't have anymore adjustment on the driver side to fix the toe?? If so it sound like the rack and pinion was not centered when put in. It was turned to far to the right when you attached the steering shaft.
Old Oct 22, 2017 | 01:55 PM
Rack is exactly center. I believe the tie rod connector needs trimmed they r 6.6 inches long
