Driveshaft question
Old Nov 9, 2017 | 10:27 AM
Chevymanty's Avatar
Default Driveshaft question
I know I am probably in wrong Forum but how much leeway do I have with my driveshaft not being straight from front to back, 1 inch, 2 inch or more, example if I draw a line from trans to rear can it be off say how far?, thx Dana
Old Nov 9, 2017 | 10:34 AM
Lawhead's Avatar
You meaning the driveshaft itself or the trans in relation to the rear end?
Old Nov 9, 2017 | 10:45 AM
Chevymanty's Avatar
Default Ds
Example: say trans is pointing straight back to rear, and when I slide my driveshaft in, how many inches can I be off from being straight back, hope I make sense, thx Dana
Old Nov 9, 2017 | 10:50 AM
Lawhead's Avatar
I mean on most cars it's very gradual but I'm going to assume this is for a truck which will make the angle pretty steep, If that the case you just make sure your pinion angle and your trans are parallel with each other and it shouldn't be an issue. If one or the other is off it'll smoke U-joints left and right
Old Nov 9, 2017 | 11:01 AM
Chevymanty's Avatar
Default Ds
sorry I don't mean the angle I mean say as it comes back before the angle can it be off say 3 inches before I start with my angle, hope I am not confusing u, thx again Dana
Old Nov 9, 2017 | 11:07 AM
Chevymanty's Avatar
Default Ds
As it comes back straight how far can I push it left or right before I start with my downward angle, thx Daba
